wierd esc code 43 knock sensor problem
Old Apr 30, 2004 | 05:43 PM
lt1ownsall's Avatar
obd-1 95 lt1
Im throwing the 43 code knock sensor
So I replace the knock sensor same error
I then go and plug the laptop in and start up pcmcomm, light goes away humm I tell it to reset the code. Code doesn’t come back. Then I turn off the laptop and the code comes back I load up pcmcomm light goes out (light = ses) Click disconnect from pcmcomm light come back
Felp me
Eddie
Old Apr 30, 2004 | 10:22 PM
Did you check the single wire from the PCM to the sensor? +5V at the pin in the plug, with the plug disconnected. Reattach the plug, and read from the pin to the block, should be +2.5V.
HectorM52
Jul 30, 2017 11:46 AM
Jul 4, 2005 05:00 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
NJ SPEEDER
Jul 19, 2002 10:22 PM
