Wierd!!!!!!!!!
Old Jul 8, 2004 | 10:37 AM
RealQuick's Avatar
Wierd!!!!!!!!!
So I made changed to my comp. and played with timing and also changed gear ratio and tire size. The computer I have in there was one from Bryan @pcmforless. Well the vin on that comp is for a a caprice classic wagon with an auto and the standard gears and tires for that car. Whats wierd is that I loaded the changes (changed tranny to M6, 3.73's, 275/40-17's along with the timing table changes i made too) and loaded. the car ran better so i knew the changes went in. Now, I scan the comp a day later to see what program is on there and the changes were put back to the original (except for the timing)! Do I need to clear memory or something. How do i get it so the tune stays?
Old Jul 8, 2004 | 09:05 PM
97Z-M6's Avatar
how can you scan the car a see what program is in it. do you mean you read the pcm to see whats in it.
make the changes agian. and be sure you hit the calculate buttom then the apply button. you prbably didnt hit the apply button. just try it agin.
you are using tunercat right.
Old Jul 9, 2004 | 08:15 AM
RealQuick's Avatar
Yes sir I do have tunercat and i did read the ecm (pcm, ecu, whatever we wanna call it). I did indeed hit calculate and apply. I then made my timing changes and saved the program. I then "programmed" my ecm. The timing stayed, but the 3.73's and such didnt. I'll have to do it again like you said and see if it sticks. Thanks.
ChickenScreamer94
Jun 2, 2003 09:11 PM
OffspringZ28
May 8, 2003 10:44 AM
Dragons91RS
3rd Gen / L98 Engine Tech
Mar 4, 2003 06:06 PM
eddiezlt1
Feb 14, 2003 05:36 PM
Ninety3Z
Jan 31, 2003 06:10 PM
