Understanding PE mode
Old Mar 22, 2005 | 01:20 PM
97RedT/AWS-6's Avatar
I read an article someone posted on here that completely explained everything I was having trouble with as far as tuning and LT1 edit goes. Thank you, whoever you are! It makes sense! If I understood correctly, if you want to change your AFR under WOT, you will change the PE tables, less % change = leaner, more = richer. What is this percentage change based on? The AFR target in the Open loop vs map vs temp table?
Novo
Jun 14, 2016 02:58 AM
drt
Sep 27, 2015 04:39 PM
4586
Sep 27, 2015 01:55 PM
autoxr166
Sep 25, 2015 04:21 PM
MDZ28
11
Sep 24, 2015 09:15 AM
