Tunning for crusing with tunnercats
Old Dec 16, 2005 | 06:25 PM
  #16
infinitebird's Avatar
Re: Tunning for crusing with tunnercats
Originally Posted by Doc99SS
If in your tuner stuff, you can set stochic to 15.0, or you might consider new O2 sensors, just the front ones.
There's no way to change the target A/F in closed loop to anything other than 14.7, at least not in a global setting. You could scale the MAF table by a certain percentage or something like that, but that's slightly different.
Old Dec 16, 2005 | 06:31 PM
  #17
Originally Posted by Slow260z
NO.
An LT1 WILL increase fuel if longterm is greater than 128 when entering WOT.
When 128 or less when WOT is entered no fuel correction is made. BUT above 128 there is an increase in fuel (long term/128 is multiplied by calculated fuel time). In an LT1 the ECM does NOT always lock the long terms to 128 at WOT.
This is correct, but you can change that behavior if you want to.
You can use this program to make it always lock the BLMs to 128 regardless of what the pre-WOT value was.
Old Dec 17, 2005 | 10:23 AM
  #18
Slow260z's Avatar
I have seen that program and it is interesting. It makes no changes to viewable tunercat file but changes the assembly instructions in three locations. I believe it is forcing program to believe the long terms were 128.
Do you know a good source for disassembled code? I have disassembler etc and have torn into some code but wanted a start.
I have seen many site but seems most have inactive links like http://www.lt1edit.com/pipermail/lt1...06/012252.html
I would appreciate any help
chuyz28
Jan 27, 2015 08:53 AM
BLUETOPTA
Oct 7, 2003 01:12 PM
lt1camaroman93
Feb 5, 2003 06:18 AM
K!D
Sep 4, 2002 01:49 PM
SS SLP2
West South Central
Jun 16, 2002 10:27 PM
