tuning for idle and maf questions
Old May 22, 2006 | 12:39 AM
plan Z's Avatar
alright my idle is a little low and my lterms @ idle are a little high/rich (around 7-8 gm/sec in the maf tables) so i adjusted them a little higher (x 1.025 - 1.05), and after programming the pcm, i turned the car on and it just died after a couple seconds. i started it and had to give it gas to get it to run and when i let off, it died again. i put the previous tune back in and it's fine. i thought cutting a little fuel would help this but do i need to do something different? or something with the timing instead? what tables are normally used for adjusting idle?
Old May 22, 2006 | 05:32 AM
BlackDog's Avatar
Re: tuning for idle and maf questions
At idle, what is your IAC count?
Old May 22, 2006 | 11:45 PM
plan Z's Avatar
IAC count: there was a point that i was idling for about 40 seconds and the IAC counts went from 115 and gradually went up to 140. then went down after i started driving again.
Old May 23, 2006 | 12:05 AM
plan Z's Avatar
this is what i have the gm/sec set to in MAF table #1 for the current tune compared to the new tune that that car shuts off on.
1st column = Hz
2nd column = Current tune
3rd colump = New tune that shut off the car
Hz gm/sec gm/sec
1488 2.66 2.66
1616 3.11 3.11
1744 3.62 3.62
1872 4.18 4.18
2000 4.81 4.81
2128 5.52 5.52
2256 6.33 6.32
2384 7.22 7.17
2512 8.30 8.09
2640 9.59 9.30
2768 10.49 10.10
2896 11.43 11.00
3024 13.03 12.40
3152 12.57 13.20
3280 13.81 14.50
3408 15.91 16.70
3536 16.48 17.30
3664 18.20 19.10
3792 21.05 22.10
3920 22.66 23.80
Old May 23, 2006 | 05:02 AM
BlackDog's Avatar
I think you need to open your throttle blades a little more to get your IAC counts down to 40-60, then go from there.
Old May 23, 2006 | 08:14 PM
plan Z's Avatar
if i do that and it ends up idling too high, would i just adjust the target idle tables to put it back down?
DirtyDaveW
Dec 1, 2016 05:37 PM
edman
Jan 22, 2015 02:45 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
pete53
Dec 9, 2014 07:31 AM
formula218
Dec 2, 2014 04:27 PM
