TunerCats: Injector Flow Rate Vs DISPLAY Injector Flow Rate?
Old 08-14-2013, 07:01 AM
ENRKyle20's Avatar
Its time to get this tune ironed out. My tune has been played with so much I dont trust it any more. I am starting with a stock file from my car and starting my tune over. Its a 383. I know I need to change cylinder volume to 784.5, and my injectors are 42lb/hr GM #12613412 so I need to change injector flow rate to 42, but what about display injector flow rate? what does that even mean. Thanks so much for the help!
ENRKyle20 is offline
Old 08-14-2013, 09:21 AM
bobdec's Avatar
Re: TunerCats: Injector Flow Rate Vs DISPLAY Injector Flow Rate?
It's for Y or B body models with Driver Information Center (DIC). The Display Injector Flow Rate is used to calculate the instant/average fuel economy data. Setting is ignored on F-Body's.
bobdec is offline
Old 08-14-2013, 09:38 AM
ENRKyle20's Avatar
OK that is good. Nothing I need to worry about then. I thought it may have been that because of the word Display. Thank you so much for you quick response and help!
Old 09-14-2013, 06:58 AM
POLOVETTE 94's Avatar
I have a Corvette, and I learned about this when I took a 100+ mile trip and my display said I averaged 37.6 mpg (383 w/Vortech). I have 83lb/hr injectors, which equates to about 13.8 gal/hr. Unfortunately, the largest number allowed in this field is 8. I wrote to TC and they said it can't be raised. I guess GM wasn't thinking about injectors that big back in 94! So, I changed it to 6.9, so now I can just divide the mpg or distance to empty by 2, to get the correct numbers. And no, that is not the biggest of my concerns with the car
POLOVETTE 94 is offline
DirtyDaveW
12-01-2016 05:37 PM
10-31-2016 11:09 AM
CamaroRSguy
08-19-2002 01:52 PM
ONEBDTRNSAM
07-12-2002 10:48 PM
Quick Reply: TunerCats: Injector Flow Rate Vs DISPLAY Injector Flow Rate?
