tunercat question
Old Aug 26, 2007 | 10:36 PM
steve40's Avatar
tunercat question
in tunercat, do you know what this constant does or mean?
"vss diagnostic enable min rpm"
Old Aug 27, 2007 | 07:17 PM
11secgen's Avatar
its the minimum rpm in driveshaft revolutions to enable the ses light for a bad speed sensor.
dan
Old Aug 29, 2007 | 03:37 PM
11secgen's Avatar
also the only time people change it is when they put a high stall in, then the setting is adjusted higher than the stall of the converter.
Old Aug 29, 2007 | 05:41 PM
steve40's Avatar
ok thanks, i have a 3600rpm stall and see that its at 3000 rpm. could this have anything to do with the car not shifting at wot?
thanks
steve
Old Aug 30, 2007 | 03:57 AM
11secgen's Avatar
hmm, id bet yes.can you change it yourself?if not just buy a cable from aldlcable.com and d/l tunercats and well see if i cant help you from there.it needs to be set at least a couple of hundred above your stall, but let me look into it to make sure,ill get back to you in a day or two.in the meantime,buy a cable to program your ecm! i do it a couple of timesa week, and the first time i did it it payed for itself.its about $40 i think,well worth it.
Old Aug 30, 2007 | 04:48 AM
steve40's Avatar
i have a cable and tunercat here. i upped the value to 7000rpm, maybe i should lower it to about 4000. just have to get to a track to see if it works.
steve
BigWil
Mar 29, 2015 12:24 PM
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
