tunercat question
in tunercat, do you know what this constant does or mean?
"vss diagnostic enable min rpm" |
its the minimum rpm in driveshaft revolutions to enable the ses light for a bad speed sensor.
dan |
also the only time people change it is when they put a high stall in, then the setting is adjusted higher than the stall of the converter.
ok thanks, i have a 3600rpm stall and see that its at 3000 rpm. could this have anything to do with the car not shifting at wot?
thanks steve |
hmm, id bet yes.can you change it yourself?if not just buy a cable from aldlcable.com and d/l tunercats and well see if i cant help you from there.it needs to be set at least a couple of hundred above your stall, but let me look into it to make sure,ill get back to you in a day or two.in the meantime,buy a cable to program your ecm! i do it a couple of timesa week, and the first time i did it it payed for itself.its about $40 i think,well worth it.
i have a cable and tunercat here. i upped the value to 7000rpm, maybe i should lower it to about 4000. just have to get to a track to see if it works.
steve |
