TTS datamaster pcm sync problems
Old Jan 25, 2004 | 02:08 PM
Botch's Avatar
I am working on a 97 z28 with a 95 pcm and I can't get the laptop to sync with the PCM. It will detect the PCM with the "Test Com" function, but will give me the alert "no pcm sync recycling" and never start datalogging. I found the help section that suggests adjusting the ALDL link timing and I have tried that and still have not had any luck. I can program through the cable and read through it with Tuner CAT so I know it works. Any suggestions?
Thanks,
Botch
Old Jan 26, 2004 | 12:07 AM
Botch's Avatar
Cool,
I figured it out! I am scanning without any problems. I had to go to Options, Advanced, check "disable ccm handshake" and it works like a charm. I just about gave up, have no idea WTF a CCM handshake is, and just clicked it out of frustration, but it worked!
Botch
Old Apr 17, 2004 | 12:22 AM
Cam94Z28's Avatar
I have been having trouble getting datamaster to work, but I don't see any of those options anywhere. The only configuration option i have is to select the vehicle type. Pcmcomm, and freescan work fine, but I cannot get datamaster to do anything.
What version are you running?
Old Apr 17, 2004 | 01:58 AM
Lt1tko5o's Avatar
I believe he is using version 3.4.17 beta as I am, It has these options, Are you using a usb adapter?
Brian
Old Apr 17, 2004 | 02:01 AM
Cam94Z28's Avatar
nope, direct serial, I have a cable from mastach.com. I have 3.4.17 on my laptop, and those options are not there.
These are the only options i have under the setup menu....
Old Apr 17, 2004 | 04:31 PM
smoknta's Avatar
you will not find those options until you open the record window,
select file, record aldl data. Once this is open select options, advanced and you will see what he is talking about.
Old Apr 18, 2004 | 11:57 PM
Cam94Z28's Avatar
thank you! That's what i was missing. I didnt' want to waste any of my free logs, so i didn't want to select that option until i had the program working properly.
DirtyDaveW
Dec 1, 2016 05:37 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
97SSdude
Dec 31, 2014 07:43 PM
Achilles97
Sep 13, 2002 10:49 AM
Captain Kirk
Jul 26, 2002 06:39 PM
