tell me the diiferents
Old May 17, 2008 | 10:44 PM
lt1street's Avatar
OK guys tell me what to do with these two tables,% change to fuel/air ratio VS cool temp at WOt and %change to fuel/air ratio vs rpm at WOt.
I see poeple will zero out the coolant temp and some pple dont. what do u guys think ?
Old May 18, 2008 | 12:31 AM
WS6T3RROR's Avatar
First adjust the coolant temp one so its the same in any normal operating range. Then if you need to adjust the entire curve and its pretty flat everywhere, you can adjust the whole range using the coolant temp enrichment values. Use the rpm table for making fine adjustments to problem areas until you get it pretty flat everywhere if its not already.
If you're starting out most of your work should be done in the rpm wot table though imo.
oldsca
Dec 21, 2006 06:30 PM
austin95z
Feb 3, 2006 08:58 PM
TJ Chapman
Sep 6, 2005 07:15 PM
BCAUTOSOUND
Jun 19, 2005 01:40 AM
Jason Pittman
Feb 9, 2005 10:52 PM
