Setting fan on/off points in TunerCat
Old Jun 24, 2007 | 02:53 PM
Black97SS's Avatar
The car in my sig currently is running the original PCM. I recently bought TunerCat and the $EE definition file. I also bought a cable for my car from AKM Cables. I don't have an OBDI PCM yet, but in the meantime I am trying to familiarize myself with TunerCat. I want to create a calibration file that comes close to what I am using now to start with when I get my OBDI PCM. To that end I downloaded several calibration files and began playing around with them in Tunercat.
I figured the first thing I would do was work on the fan on/off points so I would have them turning on early to complement my 160* thermostat.
Right away I began having trouble, While looking in the 'ECM Constants' section I could not find some of the tables that are described in the sticky by Dan K, at the top of this page, or in the help file for the ECM definition file in TunerCats.
Here is the list of all the tables listed in my 'ECM Constants' section. I would appreciate it greatly if someone could take a look at this list and let me know if it looks like yours or if I have some tables missing, especially in the fan on/off category.
1. Cylinder Volume
2. Injector Flow Rate
3. Display Injector Flow Rate
4. MAP Threshold to Enable WOT
5. Cool Thresh For TPS For WOT (High Temp)
6. EGR Enable, Min. MAP
7. EGR Enable, Min. RPM
8. EGR Enable, Max. RPM
9. EGR Enable Colant Temp (Hi Startup Mat)
10.EGR Enable Colant Temp (Low Startup Mat)
11.Fan Hysteresis Low Speed (MPH)
12.Fan Hysteresis High Speed (MPH)
13.Fan Threshold High Speed (MPH)
14.Fan 1 On, Oil Temp, (Low RPM)
15.Fan 1 On, Oil Temp, (High RPM)
16.Fan 2 On, Oil Temp, (Low RPM)
17.Fan 2 On, Oil Temp, (High RPM)
18.Fan Oil Temperature Hysteresis
19.Fan Enable, (High RPM, High Oil Temp)
20.Fan 1 On High A/C Pressure Threshold
21.Fan 1 Off High A/C Pressure Threshold
22.Fan 1 Disable MPH, High A/C Pressure
23.Fan 1 Enable MPH, High A/C Pressure
24.Fan 2 On High A/C Pressure Threshold
25.Fan 2 Off High A/C Pressure Threshold
26.Fan 2 Disable MPH, High A/C Pressure
27.Fan 2 Enable MPH, High A/C Pressure
28.Fuel Cutoff Speed
29.Fuel Resume Speed
30.Fuel Cutoff, 1st Gear
31.Fuel Cutoff, 2nd-6th Gear
32.Fuel Resume, 1st Gear
33.Fuel Resume, 2nd-6th Gear
34.Error 32, Min Diff. MAP Test Value
35.Speedometer Scalar
36.Speedometer Scalar, Fraction
37.Speedometer Scalar, (Scan Tool)
38.Speed Pulses Per Driveshaft Revolution
39.Time Between Pulses For 'Stop'
40.Vss Diagnostic Enable Min RPM
41.Min. Coolant Temp. For CAT Protect
42.Min. Coolant Temp. To Enable C.A.R.S.
43.Speed Threshold To Enable C.A.R.S.
44.Speed Threshold To Disable C.A.R.S.
45.RPM Threshold To Disable C.A.R.S.
46.%TPS Threshold To Disable C.A.R.S.
47.Low PRNDL Upshift Speed Threshold
48.Low PRNDL Downshift Speed Threshold
49.Maximum Line Pressure
50.Kickdown Mode Enable TPS Threshold
51.Kickdown Mode Disable TPS Threshold
52.Min. Cool. Temp. For Closed Loop
53.Min. Cool. Temp. For Closed Loop, Cold MAT
54.Minimum BLM
55.Maximum BLM
56.Minimum Keep-Alive BLM
57.Maximum Keep-Alive BLM
58.BLM Cell MAP Boundary Hysteresis
59.BLM Cell RPM Boundary Hysteresis
60.Individual Cyl. Fuel Trim Disable %TPS
61.DFCO Enable RPM Threshold
62.DFCO Disable RPM Threshold
63.DFCO Enable MAP Threshold
64.DFCO Disable MAP Threshold
65.DFCO Disable RPM Decrease Threshold
66.DFCO Enable Coolant Temp. Threshold
67.DFCO Enable MPH Threshold
68.DFCO Enable Delay Timer
69.DFCO Spark Retard
70.Knock Retard Enable Coolant Temp.
71.Burst Knock Enable %Diff Air Flow Thresh
72.Burst Knock Enable Coolant Temp Thresh
73.Low Octane Comp. Attack Gain MAP Enable
74.Low Octane Attack Gain Delta MAP Disable
75.Low Octane Compensation Decay Gain
76.Spark Advance Table Bias
77.Spark Coolant Temp Correction Bias
78.Min Spark Advance Bias
79.Spark Reference Angle
80.Maximum Spark Advance
81.Min. Coolant Temp. To Enable Air Pump
82.Default Minimum IAC Keep Alive Steps
83.Closed Loop Idle Enable Vehicle Speed
84.A/C Clutch Disable %TPS Threshold
85.A/C Disable Evap Temp Threshold
86.A/C Enable Evap Temp Threshold
87.CAT Overtemp Threshold (Low Baro)
88.CAT Overtemp Threshold (Mid Baro)
89.CAT Overtemp Threshold (High Baro)
90.CAT Overtemp Baro Threshold 1
91.CAT Overtemp Baro Threshold 2
92.CAT Overtemp AFR
93.Hi Temp Enrich Enable Coolant Temp.
94.Hi Temp Enrich Disable Coolant Temp.
95.High Coolant Temp. Min. Enrich AFR
96.High Temp. Enrich Enable Delay
97.Tach Signal High Period
Old Jun 24, 2007 | 03:21 PM
DOOM Master's Avatar
Well, the constants for changing the fans on/off temperature are
Fan 1 On Threshold (Low MPH)
Fan 1 On Threshold (High MPH)
Fan 2 On Threshold (Low MPH)
Fan 2 On Threshold (High MPH)
These should be between constant EGR Enable Colant Temp (Low Startup Mat) and Fan Hysteresis Low Speed (MPH), numbers 10 and 11 on your list. I'm not sure why they aren't there, though, perhaps you should try emailing Tunercat.
Perhaps you ended up with a corrupt $EE definition file and that is why they are missing? It's the only thing I can think of off the top of my head.
Old Jun 25, 2007 | 11:24 AM
LiENUS's Avatar
That sticky needs to be updater tunercat has a new EE definition file that moves the fan turn on points from the constants table to their own table, I believe it is the "Fan enable coolant temp Vs. Speed" table that contains what you are looking for.
Old Jun 25, 2007 | 11:58 AM
Ah, that would probably explain it then. I still have the older def file I guess. Time to get those updates on my tuner laptop.
Old Jun 25, 2007 | 09:54 PM
Black97SS's Avatar
Thank you all for your input, I did email TC with this question and received this answer:
Sorry for the confusion. The Fan on/off points were recently moved to a table called 'Fan Enable Coolant Temp Vs. Speed' located in the tables section. This was done to free up some space to add some new constants. The help file hasn't been updated yet.
Best regards,
TC
It would be great if the sticky could be updated to reflect this change.
DirtyDaveW
Dec 1, 2016 05:37 PM
meissen
Jun 1, 2015 07:59 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Matt-01-SS
Aug 2, 2002 04:05 PM
