Set WOT shifts on a 4L60E?
Old Oct 19, 2018 | 11:57 AM
xcesive's Avatar
I have a 1997 Camaro LT1 with a 4L60, how can I set WOT shifts?Car has - worked trans manual shifts 1st thru 3rd automatic shifts D and OD, 2500 converter, also heads, cam and rear. It pulls strong up to 6000/6200 but won't shift until 6800 (factory tach). I want to set WOT shift's at 6000.I've been thinking about installing a TORQUHEAD LS PCM and Coil Conversion Kit. But, the car runs good as it is and if I can make the trans shift, for now I would be happy and it would save me a LOT of money.
George
Old Oct 20, 2018 | 06:38 PM
re: Set WOT shifts on a 4L60E?
The gear change if large enough, can cause no shift at WOT. Scroll way down in this tuning guide, for “Shift Points”. The guy that wrote the tuning guide also does mail order tuning. Not sure how good his trans tuning is.... haven’t seen a lot of feedback one way or the other.
LT1 PCM Tuning - Tips & Tricks for DIY Tuning!
There's also a guy named Moe who hangs out on lt1tech.com that is supposed to be real good with LT1 tunes. His business is Moe Horsepower, and his advert on lt1tech.com should have his contact info.
Old Oct 21, 2018 | 11:16 AM
xcesive's Avatar
Re: Set WOT shifts on a 4L60E?
Thanks Fred, I'll check them out.
George
Cerridius
Jul 16, 2014 07:48 PM
sbca96
Feb 4, 2009 11:14 AM
BLUETOPTA
Jun 8, 2007 06:50 PM
MAGIC Z
Nov 23, 2005 12:08 AM
RacingTiger04
12
Apr 6, 2005 08:29 PM
