Quick ECU question
Old Oct 21, 2003 | 05:22 PM
fulloutpwr's Avatar
Quick ECU question
Are the fans on the f-bodys grounded through the computer? I know they were on my fox, so im wondering on a couple issues and tracing them back to my ecu... fans like to come on whenever they want and usually dont when the car is hot low- trac light turns on with the car just sitting and i dont have trac control, etc..
Old Oct 25, 2003 | 03:56 AM
raul.garcia's Avatar
my 88' only grounds one fan. I currently use the 89' prom to eliminate the 9th injector, but it also only grounds one fan, the other is grounded by a thermal switch, it's on the starter side of the block between cylinders 4 & 6. The computer compares the coolant temperature sensor (on front of intake manifold underneath the Throttle body) reading with the programmed on/off values to operate the fan.
Hope this helps.
Old Oct 26, 2003 | 01:47 PM
You might want to check the wiring diagrams available on Shoebox's tech pages. All his stuff is for a 1995, but Idoubt there are a lot of differences on the fan controls.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
Jonnybegood
Parts Wanted
Feb 10, 2015 07:50 AM
