Programming Keyless romte for '98 ls1
Old Jul 19, 2004 | 08:19 PM
TNH's Avatar
TNH
Anybody know where I can find out how to program my keyless remote to my stock alarm on my '98 camaro?
Old Jul 19, 2004 | 08:36 PM
Re: Programming Keyless romte for '98 ls1
Owner's manual:
Have each transmitter you intend to match ready for the
next steps. To match transmitters to your vehicle:
1. Turn the ignition to RUN, then to OFF. This
will disarm the Vehicle and Content
Theft-Deterrent/Alarm System (if your vehicle
has this option).
2. Remove the RADIO fuse. This fuse is located in the
main fuse block which is located on the left side of
your main instrument panel. When the fuse block is
open the radio fuse is located on the lower right hand
corner of your instrument panel. See “Fuses and
Circuit Breakers’’ in the Index.
3. Turn the ignition from OFF to RUN three times
quickly (within five seconds). The vehicle will
respond by locking the doors, unlocking the driver’s
doors and releasing the hatch. Your transmitter is
now ready to match the vehicle.
4. Press and hold the LOCK and UNLOCK buttons on
the first transmitter for 15 seconds. The vehicle will
respond as in Step 3.
5. Repeat Step 4 for the remaining transmitters.
6. When you have finished matching all of your
7. Check that all transmitters work by pressing
If the transmitters don’t work, or if you’d rather not
match the transmitters yourself, see your dealer.
Ericksd
Jan 20, 2016 06:07 PM
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
Hal Fisher
Sep 30, 2015 09:03 PM
MDZ28
11
Sep 24, 2015 09:15 AM
