Fixing exhaust leak made split BLMs much worse!
Old Jul 19, 2004 | 08:28 AM
Dr. X's Avatar
The right header gasket on my 95 Caprice was leaking something awful. Before changing the gasket, my BLMs were split slightly. Today, after having the gasket replaced, my BLMS are very widely split - 144 on one side and 128 on the other, especially at idle and light loads/light throttle. What can cause this?
BTW, the car is a 95, OBDI, tuned initially by Bryan Herter, with a 383 Golen's engine in it (new), new Hooker shorty headers, new Flowmaster exhaust, new O2 sensors.
Thanks!
Old Jul 19, 2004 | 10:24 AM
Dr. X's Avatar
Re: Fixing exhaust leak made split BLMs much worse!
BTW, the cam is 220/230 with 114, with new O2 sensors. I did recently clean the TB, but while on the car. Will probably remove from the car and clean the right way - it's incredible how much oil was in the intake when I sprayed the cleaner in - WOW!
Any other suggestions?
Old Jul 20, 2004 | 01:38 AM
bunker's Avatar
try closing your throttle blades with the idle screw, this will redirect more of the air to go through the IAC passages instead of the blades & fix up the split.
Matt.
Old Jul 20, 2004 | 07:09 AM
Fastbird93's Avatar
Matt.
Unfortunately that doesn't always work, as I'm chasing a similar problem, and while closing the throttle blades helps, it didn't quite cure it.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Brake_L8
Jan 20, 2015 09:44 AM
Joes96z
Dec 13, 2014 07:48 PM
