possible to update a "tuned" PCM from A4 to M6?
Old Jun 20, 2008 | 02:20 PM
drptop70ss's Avatar
I have a 1995 Z28 with a modified LT1 (cam, headwork, supercharger, etc) and the PCM has been custom tuned for the engine. I want to switch from the A4 to a M6. I have read that it is best to go with a M6 program when doing the conversion. If I sent this PCM out to get programmed will they be able to dump my existing tune info to disk or print it out so they would have that information? I assume I would need the M6 stock program loaded on my PCM and then updated with my custom tune info. Would I be able to do all of this if I bought the tunercat software?
Old Jun 20, 2008 | 06:41 PM
rngilliland's Avatar
You do need to use a M6 program if you swap transmissions.
Tunercat can be used to copy the tables from your current program to the M6 program. I'm sure any of the tuners could do it too.
Old Jun 20, 2008 | 07:17 PM
drptop70ss's Avatar
Great, thanks for the response!
Old Jun 21, 2008 | 12:01 AM
CamaroKid89RS's Avatar
What all is involved in changing the tune from a4 to m6 in tunercat? Is it just going into the ECM constant table and disabling the auto trans option?
Old Jun 21, 2008 | 03:46 PM
sbs's Avatar
sbs
See this post:
https://www.camaroz28.com/forums/sho...91&postcount=2
Old Jun 22, 2008 | 11:41 AM
Well then, I still need a stock M6 95 tune then, so I can transfer settings from my current tune over. Email to kale___9@hotmail.com please.
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
