P0300 code flashing even after being disabled!?!?
Old Aug 17, 2002 | 01:17 PM
Jon 97TA's Avatar
Post P0300 code flashing even after being disabled!?!?
I sent off to Brian at pcmforless to get a better tune than the ed wright tune I got. The first pcm I got from him flashed a P0300 random misfire code(the ses light just flashes and stores freeze frame data) and will not lock the converter at speed, it also disconnects my autotap program from the pcm, so everytime the ses flashes autotap has to reconnect. I talked to Brian and he said he would disable the P0300 code for me. He sent me a different pcm this time, just in case it was the pcm, and I still have the exact same problems. Has anyone had any experience like this, or every had a problem with this that knows how to help? It runs a lot stronger, so I wanna make this programming work.
TIA
Jon
[This message has been edited by Jon 97TA (edited August 17, 2002).]
Old Aug 17, 2002 | 06:58 PM
KenP's Avatar
Post
Jon, my 96 OBDII PCM would also throw the P0300 code after I disabled it with an old version of LT1 Edit. The new version of Edit added a "T-side" and an "E-side" to toggle to "off" to turn this code off. The old version did not have this. I am sure you have the same problem, ie. only one side is turned off and this is why the code keeps setting.
HTH
Kenny
    Old Aug 17, 2002 | 09:32 PM
    96z's Avatar
    96z
    Post
    I got the same problem after being disabled too?? Mine will flash only after I get on it though....
    96 black Z28 A4
    GTP heads, GTP cam, bolt ons...
    Mattucci Motorsports WNYFA FLFB
    So far...12.7@108...need more practice...
    The Z
    Old Aug 19, 2002 | 01:13 PM
    Jon 97TA's Avatar
    Post
    Thanks for the replies. Here's my sig I forgot to post before.
    Jon
    A4, 3.73 gears, Flowmaster Cat Back, LT4 KM, Prostars with 275/50/15 BFG Drag Radials, K&N FIPK, TB Bypass, Lakewood LCA’s, JBA headers, LT4 Hot Cam kit w/ 1.6 RR’s, LT4 Timing chain, hollowed Cats, Ed Wright Programming, Spohn torque arm, 52mm TB, BMR SFC's, Yank SY3500
    Heathen1
    Jan 2, 2016 04:27 PM
    kallcium
    V6 Tech
    Oct 7, 2015 03:39 PM
    LingenfelterZ28
    May 20, 2015 10:17 AM
    captcorvette
    Mar 7, 2015 12:37 PM
    91Bird305
    Aug 5, 2002 01:39 PM
