OPEN LOOP ONLY question
Old Oct 4, 2002 | 02:55 PM
FireAm94's Avatar
I have chosen to go with open loop tuning. I am trying to get a base to start tuning. Does anyone know what the pcm starts the AFR at approximately? I just want to know where to start.
Old Oct 4, 2002 | 06:38 PM
RunRiot's Avatar
AFR depends on coolant temp and intake vacuum. I can't tell you what AFR it "starts" at since it depends on those 2 values.
Check the "open loop temp vs. load" table, that's what you will be editing. Note that the AFR's listed will only be close if your injector constant is accurate.
Old Oct 4, 2002 | 09:46 PM
FireAm94's Avatar
What are most guys running as a constant for svo 30lb'ers?
Thanx for the response.
Joe
Old Oct 6, 2002 | 11:35 PM
FilledWithFurySS's Avatar
I ran an open loop...Make sure you have some sort of resistance..Or it will equal problems
~Mike
Old Oct 6, 2002 | 11:52 PM
FireAm94's Avatar
Wink
What do you mean resistance? I'm lost here. lol
Joe
DirtyDaveW
Dec 1, 2016 05:37 PM
oldschool
Feb 9, 2016 09:21 PM
grgguy
17
Feb 23, 2015 07:57 PM
Fred94LT1
Aug 24, 2002 08:07 AM
Speeds8erM-1
Jul 28, 2002 06:18 PM
