OBD II port is dead
Old Sep 14, 2007 | 06:05 PM
alexmihuta's Avatar
OBD II port is dead
Hi,
I am willing to buy a 2000 SS , everything is OK, but when I pluged my Actron Scan Tool to OBD II port the tool did not powered up. Anybody knows anything about it? I know i was supposed to check pins 4 and 16 for power... there is no power on 4,16. Do you know where the circuit might be disconnected? Wireing diagaram, anyone? On some other cars (not Camaros) there is a connector wich carries the power for the OBD port. Anything like that here?
Any help is very much appreciated,
ALEX
Old Sep 14, 2007 | 06:22 PM
alexmihuta's Avatar
nobody?
Old Sep 14, 2007 | 06:36 PM
2001NBMZ28's Avatar
Check the CIG/ACCY fuse for an open - also powers the DLC port.
Old Sep 14, 2007 | 07:20 PM
dangalla's Avatar
yeah most of the time when i encounter this its usually a bad fuse
Old Sep 14, 2007 | 08:29 PM
alexmihuta's Avatar
thanks for replay.
cig/accy should feed the cd and dashboard lights, right? they work just fine...
Old Sep 14, 2007 | 08:38 PM
2001NBMZ28's Avatar
Just feeds the cigarette lighter and DLC. See if the lighter is working, if not check the fuse in the main block inside the car.
Old Sep 15, 2007 | 02:09 PM
alexmihuta's Avatar
will do, thank you
Old Oct 25, 2007 | 07:17 PM
alexmihuta's Avatar
it was the fuse...
great help,
thank you
bunker
Aug 31, 2015 01:46 PM
bunker
Aug 21, 2015 10:21 AM
Aug 7, 2015 01:26 PM
Aug 7, 2015 08:52 AM
bunker
Aug 1, 2015 09:47 PM
