No Start Problem - Have data log
Old Feb 23, 2007 | 07:40 PM
tireburnin's Avatar
I have spark and I have fuel, but the motor will not fire. I pulled a spark plug and could smell fuel. I then left the wire off and turned it over and saw spark.
I can crank the car over for a minute and it wont fire off. It will get fuel and then "jump" a couple hundred rpm, but not start.
All I can guess is that the timing or the fuel injector pulse width is off? What is timing supposed to be set at for startup?
I can email the log to anyone for any ideas from the brief log of me cranking the car over.
Car Mods - 383 with vortec T Trim, Crane ignition, 50ish lb injectors, 224-230 cam. Car started fine prior to adding the wideband and boost gauges which I assume are unrelated to the problem.
DirtyDaveW
Dec 1, 2016 05:37 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
2_shady
Jun 30, 2002 11:24 PM
