No power to diagnostic port?
Old Mar 20, 2008 | 08:36 PM
rusnrno's Avatar
My Son's girlfriend has a 96 Camaro with a 3.8. They're trying to smog check the car but the SES light is on. They asked me to help so I took my code reader tool over and plugged it in. Nothing happened, I turned the key on anyway and still nothing. It's like there's no power to the diagnostic plug. We tried removing the PCM fuse and even disconnected the neg Battery terminal to reset the PCM, but the light will not turn off.
The car runs ok. What could be the problem?
Old Mar 20, 2008 | 10:31 PM
Power to the ALDL connector comes off the cigarette lighter circuit. Check the lighter fuse. You can't turn the light off by clearing the PCM, if the problem that's turning it on is not repaired.
Old Mar 20, 2008 | 10:51 PM
rusnrno's Avatar
Thank you Fred. I'll check the lighter fuse.
Old Mar 20, 2008 | 11:22 PM
What "code reader tool" are you using?
Old Mar 21, 2008 | 04:11 PM
rusnrno's Avatar
It's this one.
http://www.toolsource.com/obd2-reade...urceid=bizrate
Apr 29, 2015 01:43 PM
Roadie
Feb 16, 2015 10:34 AM
Double aught
Parts Wanted
Nov 23, 2014 06:11 PM
XtremeLt1
Sep 13, 2002 08:50 PM
