MAF Calibration Questions for my 95 LT1
Old Dec 26, 2009 | 09:05 AM
  #16
95Blackhawk's Avatar
I reread my first post and have come to some conclusions since then. Israel, I reference your post to discuss that conclusion which is open to everyone to evaluate.
Originally Posted by Airbornec507
Well, to report my findings of my MAF tuning by checking with my FJO wideband I do have some strange results. While running the check the pcm kept my A/F ratio right around a steady 13.2 plus or minus .2 throughout the rpm range. This is very strange as the entire time I was trying to lean the mixture out via the MAF table to get my BLMs around 128 throughout. The ST BLMs are right on and the LT BLMs are within 5 counts of 128 whether it be above at times or below 128 the LT BLMs do stay close thus confirming that the tune is close enough for the PCM to keep it to what it percieves as stoich.
Let's all agree on a few things first. One, a Bosch O2 sensor will read 0.450V at a few tenths above stoich or slightly lean. If this is the case, then GM has tried to compensate for valve overlap in the PCM program by putting the crossover at 0.425V. This last sentence is only theory but I cannot explain why they did what they did any other way.
Now let's look at your cam. LOTS more overlap than stock. This means that more fresh air is bypassing combustion and going to exhaust. This reads as a lean condition with the O2's...if you have not modified the O2 crossover. So to compensate, the PCM dumps more fuel to get to what it thinks is stoich.
This is separate from the MAF calibration. Remember you are calibrating the MAF in reference to the crossover point set in the PCM memory. Bad crossover point, bad MAF calibration in reference to TRUE stoich.
Try 400 (400mV) as your crossover and PLEASE report back. My big cam wants to know this crossover better.
Now, when I did a WOT run I got extremely lean. I think that is because the pcm saw a slightly rich condition prior to going into PE mode and took some fuel out thus leaning out the mixture while in cell 15. The WOT table is close to stock but the recommended changes by my tuning program(Excell spreadsheet) had me changing my WOT/PE table to almost +50 points from 4800rpm to 7000rpm. I have used this table many times to tune my brother's and my car in the past with very accurate result needing only about 2 or 3 runs to get the desired A/F ratio dead on. Also to not my table 4 in the MAF section maxes out at 433 AFGS at 11216Hz to attain the above BLM results. Now this may be what is playing in to the fact that I have such a high number in the WOT/PE table. Or my FJO wideband needs a little more looking at as far as set up or Wideband accuracy. Based upon what I have presented here could the theory of my MAF tables being adjusted as much actually have this affect on the WOT/PE tables?
Here, you need to put in BLM Locker. Get the BLM's to lock on 128 any time you go into WOT. Further, zero out your WOT vs RPM table. Only adjust with your temp tables. On the temp table note, get them all the same in the FULL operating temperature range so there is no variance there.
Do above as well as the O2 crossover and report back.
Ben
Old Dec 26, 2009 | 08:16 PM
  #17
Airbornec507's Avatar
As far as the temperature tables are you referring to the "%change to fuel/air ratio vs cool temp at WOT"? If so that is all set to 16 in the normal operating range from 56C to 104C.
Or are you referring to the "Open Loop AFR vs Coolant Temp vs MAP" table?
Also were is the table were I can change the crossover? I have looked over all the tables I would think that it would be in in C.A.T.S. tuner and am unable to find this function. This does sound like something that would be useful though.
I'm pretty sure I have the BLM locker in place as anytime I go to WOT it locks the BLMs out to 128 both LT and ST and uses the PE table for referance. However if I keep it from going into PE by setting the MAP threshhold to enable WOT to 255kPa in the constants I can tune strictly the MAF all the way through the RPM range(it won't lock the BLMs out in this mode unless I do some tweeking to two of the constant values in the constant table).
On another note too I emailed Racetronix and am trying to get the offset values given the entire voltage range for my injectors. I may also set my injector constant value a bit higher as well as i think 38.01 is a little low for my 38# Delphi multec injectors. If all else fails I may just use the stock offset values up the constant value and play with the individual fuel trim tables a bit then go back to the MAF tables and see if I can't get the values raised some. Even if I have to change the temperature values to get my MAF values to raise so that my PE/WOT table is not so high I may have to go that route(this is assuming that this will even work in the first place).
Hmmmm........... puzzled as to which route to take.......
Old Dec 27, 2009 | 05:38 AM
  #18
Yes this is the table.
"Fast O2 Rich/Lean Threshold" is the table.
When PE mode is enabled, the PCM will read 128 no matter what you are really at, if I remember correctly. It has been so long since I tuned without BLM Locker. Better confirm this.
Old Jan 2, 2010 | 09:20 AM
  #19
Something that worries me is the fact that while datamaster is reading Short term BLM's dead on 128 and Long Term BLM's within 3 plus or minus on both banks my wideband was registering 12.7 + or - .5 throughout the rpm range. My question is is there anywhere in the tunercat settings where the pcm can be adjusted to think that 128 BLM's is a 12.7 AFR? If so how can I get this changed to read accurately?
Thanks.
Old Jan 2, 2010 | 11:52 AM
  #20
JSK333's Avatar
As Blackhawk mentioned above, this is affected by the O2 Lean/Rich Swing Voltage table.
Also, as I mentioned above, the stock O2s will vary depending on exhaust temperature. At WOT, temp. is usually much higher than idle/part-throttle.
Old Jan 2, 2010 | 12:57 PM
  #21
Originally Posted by JSK333
Others have mentioned that exhaust temperatures can affect the accuracy of the O2 sensors. So, the same voltage at a higher temp may be a different AFR than at a lower temp. So if the temps are high enough it could be the O2s are reporting richer than it really is.
Ok so based upon the above statement by JSK333 it could be that my temperature is lower and and thus the O2s are reporting leaner than it really is making my true AFR richer than stoich(verified by the wideband). My O2s are located about 6 to 10" from the LT header flange down the exhaust stream.
1) Could this in fact be a great enough temperature drop without a catalytic converter to cause this effect?
2) Is the initial statement I made based on the quote correct?
Old Jan 3, 2010 | 09:05 AM
  #22
What Solomon said is correct but I am pretty damn sure that it would not make your final AFR be off by 1.5 points.
Old Jan 15, 2010 | 10:07 AM
  #23
ScottKnight's Avatar
These are the injectors I have:
http://www.racetronix.com/17113798.html
Based upon the link you posted it looks like a lot of trial and error would be used to get the BLMs to settle out on 128. However that would assume that all the MAF values are set back to stock, working the injector offsets first then fine tuning with the MAF values.
My question is that even by doing this how do you know that this type of injector is set correctly without having it tested in some way prior? Is there really any way to find out at this stage with the injectors in the car via BLMs(or is this really just a band-aid approach)?
Comment: I just checked my injector offsets compared to a stock file and it seems that Bryan at PCMforless has added 183 to all my values. Interesting.
This is something that I have been dealing with lately and I have to think that you are going to have a hard time dialing those injectors in without a LOT of trial and error. I tried to find a spec sheet on Delphi's site and it doesn't look like anything is available for the general public. You might ask them directly.
Here is a link to my method for scaling injectors with well-known data into the LT1 PCM. It seems to be working because the car is VERY easy to tune and idles perfectly (with a basically stock engine and SD 63# injectors at 59psi -> ~73# actual):
http://www.impalassforum.com/vBullet...d.php?t=236016
The issue isn't centered around the coordination of the squirt timing versus valve opening. The real issue is the PCM's ability to accurately predict how long it needs to open the injector for the required amount of fuel at all loads. Here is another even more detailed read on the subject:
http://calibratedsuccess.com/Assets/...%20Article.pdf
Old Feb 1, 2010 | 08:36 AM
  #24
wrd1972's Avatar
Subscribing
pete53
Dec 9, 2014 07:31 AM
formula218
Dec 2, 2014 04:27 PM
Jul 4, 2005 05:00 PM
RedLineRev
Jan 23, 2003 03:51 PM
Chrisdude
Jul 24, 2002 02:25 PM
