Negative Fuel Trim
Old Feb 1, 2010 | 01:12 AM
RallyBoy1's Avatar
Negative Fuel Trim
Using my autoxray scan tool, I have noticed that my bank 1 long term fuel trim at idle is usually at -11% while bank 2 long term is usually at 0 or -2.4%. My main concern is bank 1 and the reason for the negative fuel trim. The maf is clean, the injectors are flow matched and brand new, no exhaust leaks, I don't notice any misfires, and I can't think of anything else. Please help. Even if this is not detrimental, I would like to know how to correct this problem. I gotta find out what is wrong. What would be the best way to determine if the vehicle is misfiring? Could my valves be too tight on that side? Please help! Also, my o2's switch from high to low indicating that they are working. They are fairly new.
Old Feb 1, 2010 | 03:52 AM
95Blackhawk's Avatar
Just to eliminate the possibility, have you switched the 02 sensors from bank to bank?
Old Feb 1, 2010 | 07:48 AM
RallyBoy1's Avatar
No, I have not switched the o2's from bank to bank. Is there anything else to look for?
Old Feb 1, 2010 | 10:09 AM
just noticed that you have a bigger cam. Have you closed off your blades at idle to force all the air through the "idle air plenum"?
When cams are big and the idle air is not enough, people crack the blades to get enough air. Bad. You must do the "TB drill mod" to get the idle air correct.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 11:59 AM
cmdeshon
Dec 12, 2014 10:51 PM
LILBLKZ28SS
May 29, 2002 10:24 AM
