LS1 Injector In Lt1??!?!?
Old Jun 14, 2005 | 05:04 PM
Kryckter's Avatar
I have a friend wanting to put some LS1 injectors in a LT1.
I assume the LS1 injectors are 28 lbs. at 58 psi...
What are some constant numbers to start out and try with to get the tune close,
Im using TunerCat......
Joseph
Old Jun 14, 2005 | 06:16 PM
jay_lt4's Avatar
Re: LS1 Injector In Lt1??!?!?
you have to do some modding to make the factory lt1 clips work with the ls1 injectors, its not too hard i just used a small saw blade and made my own slots in the injectors for the clips to fit into, a dremmel tool would work also
the ls1 injectors are rated at higher fuel pressure so your really not gaining anything unless yours are bad
Old Jun 14, 2005 | 08:39 PM
madwolf's Avatar
99-00 LS1 injectors are 26.4# at 58 PSI.
97-98 and 01-03 are 28.8# at 58 PSI
We run 43.5.
The flow rate of a 99-00 on LT1 pressure is: 22.86 lb/hr.
97-98, 01-03 - 24.94 lb/hr - roughly what stock 94-97 LT1 injectors flow.
Old Jun 14, 2005 | 11:30 PM
sprayedtransam's Avatar
Joseph
B-rad?????
Old Jun 16, 2005 | 04:16 PM
Kryckter's Avatar
B-Rad....nah.....lol
You working on the guys motor from Pampa, He has LS1 injectors hes putting in that motor.....lol
Im tuning it Friday
Joseph
Thanks for all the help
Old Jun 16, 2005 | 08:09 PM
oh yeah
I don't know why I didn't even think about it being Josh...lol. I figured it would be Mr. Bolt-On Upgrade man - Brady...
Hey are you going to the track on Friday? I might be there with Ragan and Josh to run my TA through on street tires and crap gas...You can laugh at my times and driving ability!
rideordie
Nov 5, 2019 04:52 PM
Sergio
Jan 27, 2016 04:27 PM
94Z28LS1toLT1
Jan 17, 2015 08:29 PM
Jul 4, 2005 05:00 PM
