LS1 Injector In Lt1??!?!?
I have a friend wanting to put some LS1 injectors in a LT1.
I assume the LS1 injectors are 28 lbs. at 58 psi... What are some constant numbers to start out and try with to get the tune close, Im using TunerCat...... Joseph |
Re: LS1 Injector In Lt1??!?!?
you have to do some modding to make the factory lt1 clips work with the ls1 injectors, its not too hard i just used a small saw blade and made my own slots in the injectors for the clips to fit into, a dremmel tool would work also
the ls1 injectors are rated at higher fuel pressure so your really not gaining anything unless yours are bad |
99-00 LS1 injectors are 26.4# at 58 PSI.
97-98 and 01-03 are 28.8# at 58 PSI We run 43.5. The flow rate of a 99-00 on LT1 pressure is: 22.86 lb/hr. 97-98, 01-03 - 24.94 lb/hr - roughly what stock 94-97 LT1 injectors flow. |
Joseph |
B-Rad....nah.....lol
You working on the guys motor from Pampa, He has LS1 injectors hes putting in that motor.....lol Im tuning it Friday Joseph Thanks for all the help |
:think: :think: :think: oh yeah :lol: :irk:
I don't know why I didn't even think about it being Josh...lol. I figured it would be Mr. Bolt-On Upgrade man - Brady... Hey are you going to the track on Friday? I might be there with Ragan and Josh to run my TA through on street tires and crap gas...You can laugh at my times and driving ability! |
