Long Term fuel trim
Old Dec 17, 2009 | 12:44 PM
Cliffburton99's Avatar
Long Term fuel trim
What could cause my long term fuel trim bank 2 to be up at around +17% and short term stay close to 0 and both on bank 1 stay close to zero also? possibly bad inject0rs on bank 2 side? Help is greatly appreciated.
Old Dec 17, 2009 | 08:27 PM
bobdec's Avatar
Short term trims are set every so many milliseconds, so they are what's happening at that time. The ST trims update the LT trims every so many seconds , but remember the LT trims are an average of the short terms since the PCM has been powered up for an extended period. If you have a problem coming and going, or you have worked on the engine it's good practice to reset the PCM (pull battery negative cable or PCM fuse) so the LT trims start out fresh at 128 without averaging in any old readings. As far as +17% on bank 2 (right passenger side) could be anything, O2 reading incorrect, injector, manifold gasket , mechanical . Check for intake or header (exaust manifold) leaks, you can swap the O2's left to right to see if it moves, you can swap injectors left to right, etc. A data scan could help.. I assume you are OBD2, what year and model
Old Dec 17, 2009 | 09:55 PM
MikeGyver's Avatar
Once the 17% long term fueling correction has been established, the short terms are then centered or "learned" (because of the correction), so they'll be around zero.
If for example your short terms are at 15%, they will slowly adjust the long term correction until the short terms are zero; the fueling correction is then "learned".
If you have a long term split between banks then it might be a fuel injector or O2 sensor problem.
Old Dec 22, 2009 | 11:25 AM
year
The car is an all stock z28. That would make it obd2.
Old Dec 23, 2009 | 12:40 PM
Airbornec507's Avatar
94-95 are OBDI
96-97 are OBDII
What year is yours?
Old Jan 3, 2010 | 05:54 PM
Doc87IROCZ's Avatar
To determine whether its an O2 problem or not, switch the front two O2 sensors with each other, and see if the +17% LFTF follows with the O2 sensor or not. Its one trick that I've learned.
EDIT: I am thinking he has a 1999 car, so its an OBDII system.
Old Jan 3, 2010 | 06:23 PM
Originally Posted by Airbornec507
94-95 are OBDI
96-97 are OBDII
What year is yours?
Maybe he has a 99 based on his screen name - who knows????
Cliff - ADD A SIGNATURE with basic info about your car - year, model, engine, trans and any major mods. That way people cab help you without guessing.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Z28SORR
Mar 6, 2015 11:17 PM
redzed
Sep 4, 2002 06:22 PM
