TunerPro
Old Nov 25, 2009 | 11:37 AM
7designs's Avatar
TunerPro
Anyone use tunerpro?
How do i get bin from ECM?
Is there a how to or tutorial anywhere?
Old Dec 27, 2009 | 09:33 AM
7designs's Avatar
To clarify - I swapped in 94 pcm.
Can anyone answer my questions, I can use some help here?
Old Dec 27, 2009 | 12:42 PM
DOOM Master's Avatar
I doubt it. No one I know uses Tunerpro. I tested it once and found it to be very lacking in comparison with Tunercat.
Old Dec 27, 2009 | 03:40 PM
7designs's Avatar
I asked about tunerpro, I did not ask if it works with my car or mention what car I was working on.
........the question is about tunerpro software.
Old Dec 27, 2009 | 06:39 PM
7designs's Avatar
The questions I asked are not vehicle specific ...... I asked a question about a tool used, not a car part.
Old Dec 30, 2009 | 09:23 AM
ayers1967's Avatar
Maybe it's just me , But when you come on here being abrasive like this no one is every going to help you ! Just my 2 cents.
Old Dec 30, 2009 | 06:35 PM
Let's not go there..... it's been a problem, and he can't believe he did anything wrong. I've deleted as much as I possibly can, but I guess it still comes across as demanding and abrasive.
Old Dec 31, 2009 | 05:40 PM
7designs's Avatar
It's just a big misunderstanding. I did not realize I came across with an attitude.
I apologize for not being detailed enough with my questions and sounding abrasive.
Old Jan 3, 2010 | 04:44 PM
Doc87IROCZ's Avatar
FWIW: Personally, I do not think that you have an attitude. Anyway, I use both TunerPro and TunerCat. However, to get the process started (programming Eproms) you need to down load a bin file from the Eprom chip. I do this with hardware and software called the "Pocket Programmer". I have used the download feature maybe twice in the past, but have re-programmed Eprom chips about a thousand times with the Pocket Programmer. I have never used TunerPro or Tunercat to read or program Eprom, I use those two programs only for editing the bin file once I have a bin file. Do I search for 1994 bin files, maybe you can simply copy one from the internet. There use to be a library of bin files, but I think that its gone now.
Old Jan 3, 2010 | 09:26 PM
bobdec's Avatar
Ref Post # 2
. The '94 uses a flash memory style PCM (no chips). To get a .bin file from the PCM you can use TunerCat "Tuner " program to read and save yours. To get a .bin from somewhere else you have to post and ask for one. here is a site I use http://www.monodax.com/forums/tunercat-file-request/ But beware you will sometimes get people sending you incorrect files and should verify prior to loading into your PCM. I have a '94 A4, 2.73 rear stock tune that I know is good if you can use it... To run the TunerCat s/w (read, edit and load the .bin) you can download the Tuner program for free for 30 days, but you will need to download a 'definition file' for your PCM ($EE if it's a '94 F-body) at a cost of $19.95. Here's a good place to start reading about tuning http://www.lt1pcmtuning.com/tips/
88IROC_Z
Jul 22, 2015 11:38 PM
95z_28_camaro_4_Ivan
May 10, 2015 09:28 AM
1994BmtZ28
Aug 26, 2013 04:30 PM
gregrob
18
Apr 10, 2012 08:57 AM
v7guy
Jan 25, 2006 08:08 PM
