knock sensor voltage
Old Jun 3, 2008 | 07:58 PM
lt1 beast's Avatar
the ks voltage at the pcm only reads 4.6 max when the key is on. what could i do to cure the voltage problem. The car is running the LT4 knock sensor and Knock module. I need info asap, thank you in advance. Pulled a code 43 from the situation.
Old Jun 3, 2008 | 10:19 PM
4.6v is about average (it's only supposed to be 5v). I don't think you have a voltage problem. There is no specific LT4 knock sensor, but if you are running one from an LT4, it would be an OBD-II sensor and not the right one for your 1995 OBD-I computer. That would definitely give you a 43 trouble code.
Old Jun 3, 2008 | 10:33 PM
lt1 beast's Avatar
i have heard that an lt1 knock sensor and an lt4 knock module would work is this true?
The knock sensor im currently running is from a 96 corvette grandsport with the lt4 motor
Old Jun 4, 2008 | 12:16 AM
Yes. The LT4 KM works with OBD-I or II.
As I already said, that is why you have the trouble code. That knock sensor is an OBD-II sensor with a different impedance than OBD-I. Put your original knock sensor or new one meant for a 1995 in and your trouble code will go away.
Old Jun 4, 2008 | 08:50 PM
lt1 beast's Avatar
yes sir it certainly did... thank you. I replaced the knock sensor in my auto class at school today and it runs like a champ now. no trouble codes or knock what so ever.
HectorM52
Jul 30, 2017 11:46 AM
99z28 carguy
May 26, 2015 11:35 AM
4586
Mar 18, 2015 06:31 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
NJ SPEEDER
Jul 19, 2002 10:22 PM
