idle problems
Old Mar 31, 2004 | 07:58 PM
blownbird01's Avatar
idle problems
hey guys. got a question for you. My car will not idle right when the car gets warmed up. If its in park, it will idle perfect. When I come to a stop in gear, it will stall unless I keep my foot on the gas. I have an Ed Wright tune. Car runs great everywhere else. You can see in my sig what my main mods are. What can I check on a scan tool to see what is causing my problem? Any ideas would be greatly appreciated.
Old Apr 2, 2004 | 07:11 AM
LWM's Avatar
LWM
Ed Wright PCMs are locked, so you will have to send it back to him to get the idle set up a bit.
FWIW, with a 224/236 114lsa cam in a 383 with a 2,800 stall, I've got my in gear, hot, idle set at 875 rpm. Creeps a bit much, but it doesn't stall. I have my idle set up that high in order to generate vacuum.
You may want to consider eventually going with LT1 editor or Tuner Cat. It saves a lot of time, being able to make minor adjustments in just 15 minutes, instead of several days.
Hope this helps
LWM
Old Apr 3, 2004 | 12:22 AM
2MUCHZ's Avatar
Did you try drilling out the hole in the middle of your TB i had the same problem till i drilled it out a little bigger.....
Old Apr 3, 2004 | 08:42 AM
I have not tried drilling the hole out yet. How far should I go? I also have a scanner. I called Ed Wright and he told me I might have to adjust the throttle blades open. When I do the car idles too high when its cold. What values on my scanner can I look for to make sure everything working right?
lt1matt
Mar 21, 2015 07:35 PM
edman
Mar 13, 2015 09:39 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
edman
Jan 25, 2015 02:41 PM
slothgrant
Aug 22, 2002 03:01 PM
