Idle problem suggestions
Old Apr 9, 2008 | 12:04 PM
  #16
The knock sensor is right next to the motor mount. If the mount is damaged or loose, it will rattle with a rough idle, and would cause knock retard.
The question is.... is the rough idle causing a rattle that causes knock retard, or is there knock retard that if being felt as a rough idle? Do you ever have erratic knock retard results when the engine is under load, possibly indicating a sensor or wiring problem? When the PCM detects a circuit problem with the KS, it starts throwing in a variable knock retard.
Old Apr 9, 2008 | 12:17 PM
  #17
Munson's Avatar
The only time I have noticed any knock retard is when my idle will mess around up and down when i come to a stop and it will chug for a second in this case my engine does shake a good deal.. I just talked to brian at pcmforless about the problem im having with my torque converter not staying locked on the highway.. he suggested i open my tb blades a little more to prevent that.. The idle is much better now since i put the GM TPS back on it though..
Old Apr 13, 2008 | 09:34 PM
  #18
z275plus's Avatar
My 95 Z was doing the same thing, changed the tps sensor and problem solved.
Old Apr 14, 2008 | 10:50 PM
  #19
Munson's Avatar
Yeah it seems like the problem is pretty much gone with this other TPS on it.. The only time i have trouble is when i start it and go from park to reverse or something it kindof bogs down for a second..
Magenta_Hearts
Mar 5, 2015 07:01 AM
mritter1965
Feb 9, 2015 07:01 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
Rod Bender
Jan 1, 2015 03:18 PM
IRABuss
Sep 7, 2011 09:08 PM
