I hate computers
Old Aug 18, 2004 | 07:26 PM
NO CHOPSTICKS's Avatar
Angry I hate computers
I have a 69 chevelle that im putting in the 97 lt1 motor and trans. I have been told that i can run the 95 computer with the same harness to get ride of the rear O2's ! Is this true?????
also i was wondering on the body harness what can i remove to stream line it ?????
Just for some info im using the full harness from the 97 camaro from head light to tail light.
Please help
Old Aug 18, 2004 | 07:39 PM
TriPinTaZ's Avatar
Re: I hate computers
You can run a 95 PCM to get rid of the rear O2's, but you will need to change the knock sensor on the block to an OBD1 type.
Or you can send your PCM to be tuned and have the rear O2's deleted.
Old Aug 18, 2004 | 11:19 PM
ya i can get the obd1 computer for 140 canadian and the sensor i dont see being to much but do you know what i can remove out of the harness and what is the + to running the obd1 over the 2
Old Aug 19, 2004 | 07:33 AM
LWillmann's Avatar
The OBDI cars have a cheaper tuning option than the OBDII cars do. Cheaper scanning as well.
IF you switch to OBDI, you'll have to change the knock sensor or have the PCM modified to work with the OBDII knock sensor. If you switch, you'll lose misfire detection, but if you put a cam in the motor OBDII can sometimes pick up on cam lope as misfires.
frankrizz
Sep 23, 2015 04:33 PM
frankrizz
Sep 23, 2015 04:21 PM
fireside286
Sep 15, 2015 10:11 PM
350350
14
Aug 11, 2015 12:03 PM
