How to reset my iac sensor if unhooking battery doesn't work
Old Jun 9, 2010 | 11:17 PM
camarowayne's Avatar
I have replaced all sensors on my engine maf, iac, tps, and map sensor and my engine won't idle after it warms up, is there something that I am doing wrong. When it warms up it runs at 2200 rpms.
lt1 40over, aluminum heads with 208 valves, 58mm throttle body, slp pistons,1.5 roller rocker arms
Old Jun 10, 2010 | 05:11 AM
Did you set the pintle length before you installed the IAC?
Shoebox has an IAC reset procedure:
http://shbox.com/1/4th_gen_tech2.html#iac_reset
And a check procedure:
http://shbox.com/1/iac2.jpg
HectorM52
Jul 30, 2017 11:46 AM
Gtpguy
Jan 26, 2015 04:50 PM
slothgrant
Aug 22, 2002 03:01 PM
Evilfrog
Aug 7, 2002 11:36 PM
Snake Slayer
Jul 26, 2002 06:14 AM
