how do i add 1 deg of timing? - tunercat
Old May 4, 2004 | 05:18 PM
sabre81's Avatar
wondering how do i add 1 deg of timing in tunercat? What table do i use?
thanks
Old May 4, 2004 | 05:23 PM
turbo_Z's Avatar
depends on where you want that 1 degree. there is a table called main spark advance vs rpm vs map(0-4000 rpm) and an extended spark advance table directly below that which deals with 4000-7000 rpm. all you do is highlight the rpm and map that corrisponds with the area you want to increase and either type in the value you want or hit the (+) button a couple times for a full degree advance.
Old May 4, 2004 | 05:25 PM
sabre81's Avatar
i hear people saying "add 1 deg of timing across the board" because of the 160 deg tstat. So i just add 2 to every value on both tables?
Old May 4, 2004 | 05:30 PM
turbo_Z's Avatar
I wouldnt waste my time with 1 degree of timing.... you will never notice a difference but if you are still going ahead with it then just highlight the entire table and hit your (+) button a couple of times. Do that to both tables.
HectorM52
Jun 23, 2016 08:42 PM
edman
Jan 22, 2015 02:45 PM
Queens94z28
Dec 20, 2014 09:11 PM
cmdeshon
Dec 12, 2014 10:51 PM
