freescan: How long to connect
Old Dec 18, 2009 | 08:49 AM
Kbird's Avatar
Download freescan and have it attached (cable) to the car (69 camaro with a 95 LT1). Key-on-engine-off. Click start/connect, see the bytes start increasing. It been going for more than 30 minutes. Doesn't seem right. Is this correct or did i do something incorrect?
Thanks,
Kevin
Old Dec 18, 2009 | 10:28 AM
MaximumJavelin's Avatar
It should be doing that while it's connected. It's just a count of how much data has been sent back and forth. If you start the car you should notice the sensor values change, and you can also log the data.
Old Dec 18, 2009 | 11:59 AM
bobdec's Avatar
If FreeScan is running and then key is turned on it takes about 10-15 seconds for PCM to start communicating with the PC. Otherwise if key is on and FreeScan is then started communications happens almost immediately. To verify it's working with key on engine off you should see RPM at 50, desired Idle RPM at 3187, MAP at close to 99, MAT (really IAT in the LT1) at actual temp on cold engine, BLM's LT & ST at 128, TPS at 0, TPS voltage (sensor diag. tab at actual voltage) and O2 voltages down near 0.04 volts (cold engine).
Old Dec 18, 2009 | 04:37 PM
94ZRagtop's Avatar
Did you tick the "Interact with PCM" box? You have to do that with Freescan in order for it to work.
Old Dec 18, 2009 | 07:36 PM
Kbird's Avatar
bobdc - when I looked at the sensor data I didn't see any values.
I have an OBD1 ECM, I have selected vehicle as GM 1994 Camaro Z28-Impala SS - Corvette (LT1). Assume this would be ok.
94ZTagTop - I don't see an "interact with PCM box" I clicked the "start" button under the Control tab within the Communications with ECM section. COM port is 4 which is what the cable is linked to.
I ran the battery dead. I'll start the car tomorrow and see if data comes through.
Kevin
Old Dec 19, 2009 | 10:35 AM
bobdec's Avatar
To clarify on control tab screen over towards the right "FreeScan Operational Mode" box, select Force Data -> 'Interact' button. Then click start communications w/ECU. Is your Status Message window scrolling messages after you start communications ? Also.. GM 1994 Camaro Z28-Impala SS - Corvette (LT1) is the correct vehicle selection for a '95 LT1 f-body. What type of cable are you using (straight USB or serial /USB adapter) ? and what operating system (95/98/XP/Vista) ?
Old Dec 20, 2009 | 10:26 AM
Kbird's Avatar
bobdec - thanks for the help. Setting the force data - interact did the trick.
Kevin
Old Dec 20, 2009 | 11:25 AM
Airbornec507's Avatar
Is the driver for the cable installed? If not it will not work correctly because it will not recognize the hardware. You will not get a fault message either. Ask me how I know......lol. I've got about 2 pcmcia cards I've been through and two sets of USB conversion cables. Many kinds of usb cables will not work due to the transfer rate not being adequate. I do know that a keyspan will work though. If you need a model number just let me know and I'll go out to my car and get the number off my cable.
oops to slow..........I see you got it working.
Old Dec 20, 2009 | 12:51 PM
Wild1's Avatar
Many USB cables will not work due to the transfer rate. - Stated earlier
Maybe that is my concern too. I have the AKM Cable with the Serial/USB converter AND I installed the driver. I get the Status Message window scrolling fast but no data on the Engine Data or Dashboard. Could that be why I don't see the data but get activity in the Status Message window?
Old Dec 20, 2009 | 07:17 PM
Kbird's Avatar
I was getting activity on the status message window but no dtc's or sensor information. i change the force data setting. I got my DTC and saw the sensor data.
Kevin
Victor Lamb
Aug 26, 2017 02:52 PM
MDZ28
Exhaust System
Apr 29, 2015 07:44 PM
Jul 4, 2005 05:00 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
Doug Harden
11
Jul 14, 2002 04:31 PM
