EPROM type for socketing OBDI LT1 PCMs?
Old May 22, 2004 | 07:22 PM
JSK333's Avatar
Can anyone give me the part/serial # for the EPROM people are using to socket the OBDI PCMs?
Karl at Xtronics tells me that as long as the EPROM is supported, that I could use two Romutators on a socketed LT1 PCM in order to real-time tune with RT Tuner.
So, I need to find out what EPROM is used when socketing!
Thanks!
Old May 22, 2004 | 10:01 PM
mtxpert's Avatar
They are Intel AN28F512 flash chips.
Mike
Old May 23, 2004 | 04:27 AM
arnie's Avatar
Which is not an EPROM.
Old May 23, 2004 | 11:53 AM
JSK333's Avatar
So what chips are used when they are socketed? Or am I misunderstanding it?
Is there a way to socket it with two EPROM chips?
Old May 23, 2004 | 12:02 PM
mtxpert's Avatar
Nope....
The flash chips hold the memory on the PCM. I don't know that you could live edit the values as the PCM only loads these values during boot as far as I understand.
Mike
Old May 25, 2004 | 08:50 AM
texanmutt's Avatar
Lt1 PCMs have holes that connect to the flash chip that 2 row header can be soldered to. Craig Moates is working on a way to connect this to his chip emulator so you can tune in real time.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
Jan 5, 2015 07:14 PM
Jul 4, 2005 05:00 PM
JSK333
Sep 9, 2002 10:33 PM
