dtc 83
dtc 83
i am getting a dtc 83 (tcc control feedback) after a tranny rebuild.
ne1 know what this means, or how to fix it. i have the service manual, but it only mentions the code for manuals, not autos.
well the tcc would be the lockup solenoid (overdrive)
So I would check the continuity of the lockup sol.
It takes only 2 wires. A 12v wire from a fuse and the other wire comes from the PCM.
I would guess that the wires inside the tranny are maybe pinched or not hooked up to the solenoid during rebuild. you can pull the pan and take a look.
Before doing anything......is your overdrive working?
tommalcolm
Sep 11, 2015 03:39 PM
