dtc 83
Old Feb 13, 2004 | 01:35 PM
conquest lt1's Avatar
dtc 83
i am getting a dtc 83 (tcc control feedback) after a tranny rebuild.
ne1 know what this means, or how to fix it. i have the service manual, but it only mentions the code for manuals, not autos.
Old Feb 14, 2004 | 10:28 PM
JDBlaze85's Avatar
well the tcc would be the lockup solenoid (overdrive)
So I would check the continuity of the lockup sol.
It takes only 2 wires. A 12v wire from a fuse and the other wire comes from the PCM.
I would guess that the wires inside the tranny are maybe pinched or not hooked up to the solenoid during rebuild. you can pull the pan and take a look.
Before doing anything......is your overdrive working?
Old Feb 20, 2004 | 08:27 AM
aboadnan's Avatar
Is your car 1995 if so check TCC pwm solenid it is an extra
solenoid for the tcc which sets beside 3-2 solenoid .
May be you have 1994 tranny (no tcc pwm).
Or you have 1995 program in 1994 car.
KYWes
Sep 26, 2015 08:49 AM
MDZ28
11
Sep 24, 2015 09:15 AM
tommalcolm
Sep 11, 2015 03:39 PM
MDZ28
Sep 7, 2015 09:16 PM
4586
Aug 24, 2015 11:04 PM
