tips for running obd-2.com diagnostic software
Old Feb 6, 2004 | 08:38 PM
teke184's Avatar
just got the cable tonite...only tried it out once...
have difficulties getting some of the real time data i would like.
anyone using this and familiar with how to set it up.
so far i've found how to watch some of the data and how to read codes, but i couldn't figure out how to look at the log to see how things changed over time.
one thing i want to check out is what my redline is...mostly to confirm that it is at the stock 6200 since the tach is not very accurate.
Old Feb 9, 2004 | 12:15 PM
teke184's Avatar
doesn't anybody use this?
i'm not looking for tuning...just how to watch what the engine is actually doing.
Old Feb 17, 2004 | 11:19 PM
EviLBoX's Avatar
Did you install the enhanced LT1 file? That adds a ton of additional sensors you can watch. What specifically do you want to monitor?
Old Feb 18, 2004 | 09:32 AM
teke184's Avatar
i downloaded it, but not sure how to access it.
i got some directions from alex (creator) but havn't tried it yet.
one thing i really want to look at is knock retard...to see if i'm getting any.
i just ordered some plugs/wires cause i'm chasing a random misfire. so i'm kindda on hold till i do that.
Old Feb 20, 2004 | 11:06 AM
EviLBoX's Avatar
If you put that file in the correct folder, you should just go to the "Enhanced" menu, then choose your car under the options. That's the menu that has knock retard and all that stuff in it.
If you're chasing a random misfire, the "enhanced" menu will allow you to view the number of misfires on each cylinder. That may help.
DirtyDaveW
Dec 1, 2016 05:37 PM
InfernalVortex
Jan 17, 2015 09:35 AM
squarehead
Jan 15, 2015 07:02 PM
Double aught
Parts Wanted
Nov 23, 2014 06:11 PM
mosskeet
Jul 18, 2002 08:11 PM
