Dash lights freaking out
Old Aug 27, 2023 | 05:34 PM
SSTAT's Avatar
So I'm 'restoring' my 97 SS. the engine, trans, K member are all out. I installed an aftermarket wheel (clockspring is out, resistor placed in the airbag wire), I never went in past the steering wheel lock plate. I reconnected the battery and turned on the ignition so I could confirm that the air bag light goes off. What I actually see is both turn signal lights come on and stay on, the air bag light comes and and keeps flashing, the brake light comes on and stays on (parking brake is not pulled), security light comes and keeps flashing, and the low traction control light does a slow flash and with each flash the antilock module in the engine bay clicks loudly. Ive never touched the wiring under the dash or in the column. The wiring harness is completely factory and in great condition (the car only has 30k miles on it). Turning the key back to accessory works fine, everything come on that should with no lights on dash. Im hoping this is normal behavior with the engine/kmember/brake harness completely unplugged but it doesnt seem right. It seems doubtful anyone would know because who would turn their ignition key on with all this unplugged (again I only did to check the airbag light with new steering wheel)? Anyone know? I hope Im freaking out over nothing.
1997 Camaro SS
Old Apr 29, 2024 | 05:39 PM
SSTAT's Avatar
Re: Dash lights freaking out
Well I thought I would follow up. It turns out that yes, when you unplug every sensor in the car, and turn key on, the dash performs a full on new york city new years freak show. All better when everything is plugged in.
Old Apr 29, 2024 | 05:47 PM
RosadOC-Z
3rd Gen / L98 Engine Tech
Jun 5, 2006 10:20 AM
jons69
Classic Engine Tech
Jun 14, 2005 01:31 PM
Loading
Oct 27, 2004 01:19 AM
dhirocz
Aug 30, 2004 10:17 AM
z71camaro
Jul 24, 2004 06:20 AM
