coolant level sensor
Old Nov 8, 2005 | 04:06 PM
72ccam's Avatar
what type of resistor could i use to bypass the sensor to keep the f...ing light off in the dash. this is the 2nd sensor from gm that i ve gotten that goes bad after a few months.
Old Nov 8, 2005 | 04:08 PM
Blue89Bird's Avatar
Re: coolant level sensor
you obviously have something in your cooling system that is contaminating the sensors. Do a full flush until everything comes out crystal clear and then replace it. Disabling the light for that is like putting a band aid on a gunshot wound, you're still going to have the problem.
Old Nov 8, 2005 | 04:39 PM
72ccam's Avatar
its a new engine new radiator , plus my wife's brand new 1500 , a buddies 1500 and another friends camaro all do the same thing . every once in a while it goes off. i called gm and they said it happens. isnt that a crock. plus i flushed the new engine out then flushed it again when the before the new radiator went in . also flushed the new radiator out before install. i know how finicky lt1s are about cooling. had the system vacced down before filling.i'll check though just for certain , thanks
Old Nov 8, 2005 | 04:59 PM
2001NBMZ28's Avatar
Some of my LS1 <2K friends just disconnected the plug to the sensor - light stays off - just check the fluid once in a while.
Old Nov 8, 2005 | 06:25 PM
moparman's Avatar
It's pretty common. Disconnect the thing.
Old Nov 8, 2005 | 06:37 PM
MOhara6012's Avatar
My has acted up lately as well, coolant level is good, system flushed.
Old Nov 8, 2005 | 07:04 PM
Silver's Avatar
mine's been disconnected for a long time. no light. it's kinda stupid though, keep a close eye on the water/temps
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
91Bird305
Aug 8, 2002 12:36 AM
