Confused on code
Re: Confused on code
See Shoebox's LT1 code list:
http://shbox.com/1/Dtcs.htm
Basically, low AC system pressure due to low R134a.
Fred, I did see that, I never had that one come up before, and have had my a/c down before. I didn't even think the PCM cared one way or another about the A/C system on OBD 1. It's strictly an A/C dtc?
Unless they changed the code from 94 to 95 (I have a 94 shop manual) it's specifically for the AC charge level.
DTC 61
A/C SYSTEM PERFORMANCE
5.7L (VIN P) "F" CARLINE (SFI)
Circuit Description:
The PCM monitors A/C refrigerant pressure and A/C evaporator temperature to determine if the A/C system has adequate refrigerant (R134a) charge. The PCM will disable the A/C clutch whenever the refrigerant charge drops below a predetermined value, to reduce the chance of compressor damage. The PCM will cycle the compressor more frequently if the charge is only slightly low......
DTC 61 Will Set When: The PCM calculates refrigerant charge to be below a predetermined level.
Action Taken (PCM will default to): If the PCM determines A/C refrigerant charge to be low, the A/C clutch will be disabled and DTC 61 will be set. DTC 61 will be stored in the PCM memory, but will not turn "ON" the Malfunction Indicator Lamp (MIL).
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
