code key
Old Mar 6, 2011 | 06:55 PM
94zz28's Avatar
code key
im new to this forum. looks like you guys know your stuff so i thought id join.
i have a 94 z28 and the check engine light comes on after about 10mins of it running. i pluged in the code key to watch the blinks of the check engine light but it never blinks. i never even get the code 12.
also Ive recently had problems with my vats system. can the performance shops usually program vats not to work? I think i have a bad pickup inside the lock cylinder.
Old Mar 6, 2011 | 09:03 PM
moparman's Avatar
Re: code key
'93 was the last year you could use that method. You'll need a code reader, scan tool, or software to pull any codes.
Old Mar 7, 2011 | 10:42 PM
CALIROCZ28's Avatar
Re: code key
on my 1995 V6 3800 Camaro I was able to flash my codes by by grounding out the ALDL connector. '96 on you cannot flash codes
Old Mar 7, 2011 | 11:17 PM
Re: code key
For the LT1, as noted in moparman's post above, 1993 was the last year you could flash the codes by shorting the ALDL pins. Will not work 94 and up, on the LT1.
Old Mar 8, 2011 | 08:31 AM
94zz28's Avatar
Re: code key
ahh well that makes sence. i thought the key would work for any gm 95 and down. thanks
liamcg97
Nov 25, 2019 05:55 PM
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
Lakebratt
Feb 5, 2015 07:55 PM
91Bird305
Aug 5, 2002 01:39 PM
tbyrne
Jul 2, 2002 05:37 PM
