code 33 map sensor high
Old Jan 17, 2004 | 01:09 AM
customredz's Avatar
anyone know whats up, the map was around .8-.9 @ idle
Old Jan 17, 2004 | 12:47 PM
Re: code 33 map sensor high
Assuming your readings are 80-90kPa, have you checked the vacuum at idle with a mechanical gauge? Unlikely a relatively stock engine would have vacuum that low, but first check it with a mechanical gauge.
Then check the harness connector for the MAP sensor..... they "dry out" and start to crumble, causing poor connections. If that is OK, check the MAP sensor. You would need access to a vacuum device, like a Mit-E-Vac. With the sensor removed from the manifold, but still attached to the harness, key on, engine not running - attach the vacuum pump to the sensor nipple and pull a vacuum while measuring signal voltage. Compare the results to the table in my ScanMaster writeup.
HectorM52
Jul 30, 2017 11:46 AM
Fatdog2
Feb 13, 2015 08:19 PM
Amshnock
14
Jan 18, 2015 11:47 AM
91Bird305
Aug 5, 2002 01:39 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
