VE Master!
VE Master!
Whats the deal, this program doesn't work worth the crap
Unless Im doing something wrong which I can't seem to think I am.
I enabled speed density in the switch table. Have my MAF removed. Logging with datamaster, the Short Term BLMS are at like 80, subtracting a $hit load of fuel.. I log like a couple of minutes of data with the car idleing in closed loop, run the file thru ve master and it shows that it didn't change crap in the little log
What the Hell? It should have lowered the numbers a ton, but it did nothing..
What's the deal?
Unless Im doing something wrong which I can't seem to think I am.I enabled speed density in the switch table. Have my MAF removed. Logging with datamaster, the Short Term BLMS are at like 80, subtracting a $hit load of fuel.. I log like a couple of minutes of data with the car idleing in closed loop, run the file thru ve master and it shows that it didn't change crap in the little log
What the Hell? It should have lowered the numbers a ton, but it did nothing..What's the deal?
I'm pretty sure VEMaster will not alter anything that occurs in cell 16.
Just do the idle stuff by yourself. Get it sorted out and then take a 20-25 minute log of part throttle and run vemaster on it. Usually 2 or 3 times is enough to get you close. Then just go in and look at the 2 ve tables and make sure that the cells seem go "flow" or are somewhat linear...meaning that the values get higher as map and rpm increase.
Thanks dude, you da man
Originally posted by MentalCaseOne
I am so lost here. My car idles with Block Learn cell 1.
are Block Learn Cells the same as the ones you mention in your
post?
Marvin
post?
Marvin
