CC306 tuning...
Old Aug 24, 2006 | 03:04 PM
  #16
ssean92's Avatar
Re: CC306 tuning...
i downloaded them but cant get them to work, well the ones that are cc306 anyways. says the format is wrong, and when i get them open the values are way off shows idle at 3k and i know that cant be right
Old Aug 25, 2006 | 10:26 AM
  #17
Sweetred95ta's Avatar
Re: CC306 tuning...
I know that the downloading format changed sometime recently and I haven't tried downloading them and openning them. Are you using $EE definition file and you have an OBDI computer? Just checking the basics.
Old Aug 25, 2006 | 11:17 AM
  #18
ssean92's Avatar
Re: CC306 tuning...
i have the obd1 i have a 95. i have tried all the diferent ways. bur yes the ee is what my monputer uses
Old Aug 25, 2006 | 06:16 PM
  #19
Matts1994Z28's Avatar
Re: CC306 tuning...
Its now saved as a zip, change the format to .lt1 and your good
Old Aug 25, 2006 | 07:06 PM
  #20
ssean92's Avatar
Re: CC306 tuning...
how do u do that???? i tried to figure that out but nothing
Old Oct 8, 2006 | 08:37 PM
  #21
Re: CC306 tuning...
anyone have any more input on this? Im actually puttin the cam in soon. about damn time....
Old Nov 6, 2006 | 05:59 AM
  #22
ssean92's Avatar
i know this has been dead for alittle while but i have gotten the cam installed and did get a tune from madz and this thing has no low end power at all. is there anyone that can help me out and see what i need to do. i can try to data logg the car using scanmaster if that would help
Old Nov 6, 2006 | 07:00 AM
  #23
ssean92's Avatar
ok i was compareing my factory tune and the madz28 tune and there seems to be a 2-3 degee loss in the madz tune from my factory tune. the degrees out i think is strange seening how this is a bigger cam and would need more timing right. am i wrong?????? i was thinking about putting back it the timing were it was removed and see if that help with the bottom end power. is there anyway that i can post the two tunes for people to look at and compare?
Old Nov 6, 2006 | 07:44 AM
  #24
You don't necessarily want to put the timing back in. The bigger the cam is, the less timing it can handle in the low rpm/high MAP areas. If you want to send the tune to me, I can look at it. I have the factory tune already. Remember, with the cc306, you're going to lose some lower end. It's inevidable with a cam that size.
Sweetred95ta@hotmail.com
Old Nov 6, 2006 | 08:07 AM
  #25
ssean92's Avatar
its coming your way
Old Nov 6, 2006 | 10:40 AM
  #26
mkent's Avatar
To go along with this, with the bigger cam timing will be retarded in lower RPM/mid MAP areas to help smooth cam surge. I've finally defeated the surge on my brother's car this weekend using this approach.
Old Nov 26, 2006 | 11:54 AM
  #27
Well im going to finally put this thing in my car in about 3 weeks so we will see how tuning goes. Sean what size stall are you running with this cam? i hear anything below a 3000 will make this cam be a dog.
mightymouse383
Jul 20, 2016 07:34 AM
Z Power
Sep 19, 2015 11:19 PM
Abdullah
Feb 6, 2003 06:23 PM
turbo_Z
Jan 31, 2003 09:45 PM
James3219
Jan 30, 2003 12:01 AM
