BLM reset? After changing Tune?
Old Apr 20, 2011 | 02:28 AM
RACEON's Avatar
I just finished retuning via HP tuners a C5. In the procedure you reset the fuel trims so the new tune will take.
Well, then I thought about my C4. Is there a way to reset the BLMs etc after changing your tune? Or does it reset automatically when you take the chip out to re-flash it, like on my 93.? I am chasing a split BLM issue, and am trying to find out if everytime I make a change if it needs resetting or just swap the chip/tune and move on.
Old Apr 20, 2011 | 05:24 AM
Re: BLM reset? After changing Tune?
Pull the "PCM BAT" fuse for 30 seconds and the data stored in the volatile memory, including the long term fuel corrections, will be lost (= reset).
Old Apr 20, 2011 | 06:57 AM
Any time I have loaded a tune, the PCM resets.
Old Apr 20, 2011 | 11:27 AM
RACEON's Avatar
Thanks Fred, I appreciate the help.
DirtyDaveW
Dec 1, 2016 05:37 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
armedtrigger
Feb 24, 2015 08:30 PM
grgguy
17
Feb 23, 2015 07:57 PM
