BLM locker won't work
Low fuel rail pressure. The LT1 fuel return regulator that is located @ the end of the rail can cause a low pressure zone. I still run an in line system, but, moved the regulator down stream with -an fittings and flex hose. In my opinion, this really helped equalize pressure distribution in both rails. I'm running 72# Siemens peak-hold injectors on a LT1 383-FI app. B.
