BLM Locker
Akm cables used to have it on their website iirc. Also, if you email tunercat and tell him specifically what you're wanting he can add it in as a flag. Or if that doesn't work, I can email you a copy of the old one.
Found this------> http://www.taekwondoplus.org/z28/WOT...cker_Setup.zip
If you are using TunerCat, just look under File;Code Patches to find the BLM Locker option you can turn on and off at will. If it is not there, you need a newer definition.
I found it there sometime last year.
Hey all,
For you TC freaks out there like me, here is what TC said in an email to me:
Hi Ben,
To lock the BLMs using the current Tuner program all you have to do is run the Tuner program, click on the 'ECM' menu and select 'PCM_EEL' instead of 'PCM_EE' as you normally would. Then either open an existing calibration file or read the PCM in the car. Then program the car's PCM and the BLMs will be locked.
To unlock the BLMs select the standard 'PCM_EE' ECM Definition File from the 'ECM' menu, open a calibration file or read the PCM and then program the PCM again.
You can download the zipped file containing the $EEL ECM Definition File and the latest version of the FormLib file go to:
Hi Ben,
Thanks 95blackhawk....
Looks like it's only for you $EE guys though. Us 93 $DA3 guys always get the shaft, lol Ran into the same thing with VEMaster when trying to use it the other day. Doesn't seem to be a version for $DA3.
Dan K
Aug 28, 2002 12:06 AM
