BLM Locker
Old Apr 11, 2010 | 09:56 AM
95Blackhawk's Avatar
BLM Locker
I cannot find online. Anyone have a copy?
Thanks,
Ben
Old Apr 11, 2010 | 12:24 PM
OutKast's Avatar
Never heard of it...what is it?
Old Apr 11, 2010 | 07:09 PM
WS6T3RROR's Avatar
Akm cables used to have it on their website iirc. Also, if you email tunercat and tell him specifically what you're wanting he can add it in as a flag. Or if that doesn't work, I can email you a copy of the old one.
Old Apr 11, 2010 | 07:50 PM
OutKast's Avatar
Found this------> http://www.taekwondoplus.org/z28/WOT...cker_Setup.zip
Old Apr 12, 2010 | 11:11 AM
ScottKnight's Avatar
If you are using TunerCat, just look under File;Code Patches to find the BLM Locker option you can turn on and off at will. If it is not there, you need a newer definition. I found it there sometime last year.
Old Apr 12, 2010 | 02:02 PM
Hey all,
For you TC freaks out there like me, here is what TC said in an email to me:
Hi Ben,
To lock the BLMs using the current Tuner program all you have to do is run the Tuner program, click on the 'ECM' menu and select 'PCM_EEL' instead of 'PCM_EE' as you normally would. Then either open an existing calibration file or read the PCM in the car. Then program the car's PCM and the BLMs will be locked.
To unlock the BLMs select the standard 'PCM_EE' ECM Definition File from the 'ECM' menu, open a calibration file or read the PCM and then program the PCM again.
You can download the zipped file containing the $EEL ECM Definition File and the latest version of the FormLib file go to:
Old Apr 12, 2010 | 02:04 PM
It is a simple program that allows you to lock BLM's at 128 when in PE mode. Makes for more accurate fueling at WOT when trying to tune.
Old Apr 13, 2010 | 11:29 AM
OutKast's Avatar
Thanks 95blackhawk....
Looks like it's only for you $EE guys though. Us 93 $DA3 guys always get the shaft, lol Ran into the same thing with VEMaster when trying to use it the other day. Doesn't seem to be a version for $DA3.
alphaauto
Jul 26, 2015 04:40 PM
KGRESOCK
Feb 19, 2003 07:54 PM
95Bird
Advanced Tech
Sep 22, 2002 10:51 PM
LVZ2881
Sep 2, 2002 12:35 PM
Dan K
Aug 28, 2002 12:06 AM
