Autotap
Old Jun 28, 2004 | 04:11 PM
TsRfBoDy's Avatar
Autotap
Is auto tap a tuning progrm or just like a monitoring system? I'm lookin to buy something just not sure and was wondering about Autotap
Old Jun 29, 2004 | 10:10 PM
PG97SS's Avatar
Autotap is just for monitoring.
Old Jun 29, 2004 | 11:06 PM
What year is your car? The "EFILive" version of AutoTap, for the LS1's, supports "bidirectional controls", that allows you to alter (as long as the system is connected to the PCM), the following parameters:
Absolute spark advance (-10 to 40)
Delta spark advance (-40 to 40)
AFR (9 to 16)
Crank position sensor relearn.
Idle air control
Cylinder balance test
MIL on/off
Skip shift lamp on/off
CC inhibit on/off
A/C clutch on/off
Low speed fan on/off
High speed fan on/off
A.I.R solenoid on/off
A.I.R pump on/off
Fuel pump on/off
Purge solenoid on/off
Vent solenoid on/off
Closed loop on/off
Fuel learn on/off
Hold gear (1, 2, 3 or 4)
TCC solenoid on/off
TCC PWM on/off
3-2 solenoid on/off
PCS current (0 to 1.1 Amps)
Reverse lockout on/off
Skip shift solenoid on/off
While not direct "programming", it does allow you to evaluate the affect of altering things like timing and target A/F ratio.
http://www.autotap.com/efilive.html
Ricardo
Nov 29, 2014 10:58 AM
LWillmann
Jun 4, 2003 11:53 PM
LWillmann
Jun 3, 2003 12:21 PM
dkeers
N2O Tech
10
Feb 9, 2003 06:43 PM
tbyrne
Jul 2, 2002 05:37 PM
